LT1 running Slugish!!! HELP!!!
Old 04-21-2006, 10:19 PM
mustang93's Avatar
Default LT1 running Sluggish!!! HELP!!!
I bought a 94 Camaro today and it runs sluggish??? What could it be... It runs fine but it is just sluggish?? Could it be the opti spark???? Just looking for ideas.. I am use to the LS1 cars not LT1 cars.. HELP!!! Thanks..
It only has 71XXX miles on it... It also kinda misses out at an idel??? HELP!!!!
Old 04-21-2006, 10:26 PM
Shirley Temple Drinker
Sgt. Spuds's Avatar
Do plugs and wires, along with running some fuel injector cleaner threw it My friends LT1 was slow as **** when he first got it, well, slow for a lt1, but he had plugs and wires put on it, along wit hthe fuel injector cleaner, and it runs great now.
Old 04-21-2006, 10:32 PM
mustang93's Avatar
Kool.... The car sat for a wile before I bought it...
Old 04-21-2006, 11:28 PM
mustang93's Avatar
TTT up
Old 04-22-2006, 11:56 PM
mustang93's Avatar
ttt top
Old 04-23-2006, 12:00 AM
In Need of Cup Holders!
LukePhillips's Avatar
Its an LT1, its ALWAYS sluggish,
Changing plugs and wires is a must. I changed mine at 100k and the car ran a hell of alot smoother afterwards. Run some Seafoam through it before you change em out though.
Dosent hurt to check the filter either. Hell, just get a k&n drop in.
Old 04-23-2006, 12:08 AM
Carter Hays's Avatar
Start with the basics, check fuel pressure, put a vacuum gauge on it the readings should be steady between 14" and 22" HG. Also try and find/borrow a scan tool to see how she is doing ecm/sensor wise.
Timing is probably off, but give it a full tune up complete with all filters and fluids can't hurt.
I'm sure it just needs a little maintenance and it will run fine.
Old 04-23-2006, 12:24 AM
mustang93's Avatar
LOL YAH!! I am use to the LS1s thats why I am asking you guys for help.... But I think I am going to put some wires and plugs on it tomarrow.... What is seafoam???
Old 04-23-2006, 04:45 AM
Shallow Bay's Avatar
Originally Posted by mustang93
What is seafoam???
Here's some information straight from them.
This is an excellent write-up on how to use it.
Old 04-23-2006, 10:46 AM
mustang93's Avatar
THANKS!
Old 04-23-2006, 01:41 PM
urbanhunter44's Avatar
Sounds like it just needs a tune-up man! Plugs/wires (pull the y-pipe to get at the plugs.. you'll thank me), fuel filter, air filter, etc.
Old 04-23-2006, 07:32 PM
mustang93's Avatar
I put some seafoam in the tank So what will happens next???I am going to replace the wores and plugs as soon as I find time..
Quick Reply: LT1 running Slugish!!! HELP!!!
