oil pressure bad after highway trips
oil pressure bad only after highway trips
okay this question is about my dad's daily driver it's a 95 S-10 2.2 4cyl. heres the problem when you start it up it makes between 40 and 60 psi. and once it warms up it goes down to about 40. but if you drive down the highway where you keep the rpm's up when you come to a stop and the motor goes down to idle it goes to 0psi and the motor starts to knock,it sounds like it comes from the lifters like they aren't staying pumped up. if you rev it the pressure will come up and it will stop making noise. but as soon as it idles it will loose pressure. if you start it cold and let it idle it will maintain pressure fine until run it down the road at a sustained higher rpm(probably 2300rpm)
we put thicker oil in it. the timing chain was replaced at a shop right before this started to happened. we found some rtv and sludge in the oil filter so we flushed the pan and put the thicker oil it and it didn't help. I thought maybe the bearings and pump where just worn out maybe and had to much gap/clearence. it does have 197,000 miles but it never a had a single problem before. the timing chain was replaced by the shop it stopped running one day and wa getting no signal from the cam pos sensor so they replaced that and said the timing chain had some slack so we had them go ahead anf replace it.
Is the oil pan full? My buddy's truck did that when it wan 4 qts low. The little bit of oil he had in the pan sloshed forward, away from the pickup tube when he stopped.
check the pump for sure because of the things is how the oil looses its consitancy when it heats up, even when u have thicker oil, the if the pump is going out then its gonna be a pain for the pump to send that thinner heated oil through....my s10 has 160k on it...mine does it alil, when its really a hot day...
