ac went out i think?
well, today here in souther cali it was fcking hot, i get out of work and try to turn on ac and it didnt blow cold air for liek 30 mins, then i decided to turn it off, they day before that it workd, what the hell? does any one know whats wrong, oh and my car is a 98 z28
There are a couple fuses and a relay you can check too. I'd also look around for any signs of oil leaking around the AC connections under the hood which would indicate a leak.
I was referring to refigerant oil from the AC. Low oil level light on the dash is from the sensor on the passenger side of the pan for engine oil, low coolant level sensor is yet another sensor for radiator coolant. There's no light that will come on specifically for AC charge being low, the sensor will just keep the compressor from coming on.
