German Castrol
Old 06-03-2006, 04:28 PM
BLKWS.6's Avatar
Default German Castrol
http://home.comcast.net/~dsmphotos/gc/gc.html
This link is for all you ppl like me who heard of it and wanted it and didnt know how to buy it because you were unaware of how to find it. Well, now you know what she looks like
Old 06-03-2006, 06:59 PM
GXPPOWER's Avatar
Default but where????
i have looked at wlamart/ oreilys/ advance/ auto zone
and none have it. their is no 0w-30 anywhere
Old 06-05-2006, 12:29 AM
98hardtopZ's Avatar
i found several cases at a local autozone...
Old 06-05-2006, 01:37 AM
wamp42's Avatar
bigger Autozones carry it. Ive got something like 25 quarts stocked up.
Old 06-05-2006, 01:51 PM
jmm98LS1's Avatar
Our bigger local Autozone always used to have a case or two in stock. They haven't had any for over six weeks now. Me thinks this is not good....
Old 06-05-2006, 01:54 PM
Mike02Z's Avatar
I've pretty much cleaned out all the AZ's in my area. None have gotten it back in stock
I do have enough for about 6 years at the rate I drive and change my oil.
Old 06-06-2006, 05:35 PM
98camaroLS1M6's Avatar
Better than rp and m1? I know I have very good things from people who have it.
Old 06-06-2006, 05:48 PM
Mike02Z's Avatar
I would not use either Royal Purple 5W-30 or M1 5W-30 in my LS1 based on the information I read over at bobistheoilguy.com. Royal Purple Racing 41 and Mobil 1 Truck/SUV seem to do very well in LS1's though.
Some people swear by M1 5w-30/RP 5W-30 and get very upset if you say it's not a good oil. It's a fine oil just not ideal for the LS1. Both tend to be on the thin side at temperature and the LS1 likes a thicker oil.
Old 06-08-2006, 12:29 PM
GXPPOWER's Avatar
Default hey stanger
the german castrol i got says european performance on the bottle.
Old 06-09-2006, 12:53 AM
wamp42's Avatar
Thats the newer bottle design. Its still the same stuff. "Made In Germany." Thats the key.
Old 06-09-2006, 02:01 AM
BLKWS.6's Avatar
My 5.0 hated M1 10-30. It made more noise and ran hotter. With Shell Rotella 15-40 the motor purrs nicely. My dad has torn apart every motor he wore out (quite a few as he used to esxoret over size loads) and experimented with a LOT of oils and even used to sell/use AMSOIL. He concluded that 15-40 shell rotella did the best in his 5.0s/4.6 crown vic pilot cars and that AMSOIL was not worth the $$.
My Experience....
THe 95 TA I bought had castroil GTX run through it...it took oil changes every 500 miles to keep from clogging the filter that Rotella cleaned so much **** out of there.
previously stated about my 5.0
a 93 crown vic with a 98 5.4L did not like Rotella T as it was a bit thick for it, it preferred GTX 10-30, then again, the motor had sat in storage a few years and after it limbered up i never tried Rotella, so I dont know
According to at least 1 oil analysis I have seen, Rotella 15/40 cut wear metals in half in one LS2 GTO as compared to M1 5-30 (or was it 10-30?).
Either way, I like the stuff, its cheap and it holds up damn well under heat, thats why big turbo trucks use it for thousands of miles
