Difficultly of changing pinion seal
Old 06-25-2006, 10:03 PM
SSucese's Avatar
Default Difficultly of changing pinion seal
After putting it off for a while now its time to start planning on swapping out my leaky pinion seal w/ a new one but would like to get some advice before doing so. First quesiton I have is in regards to a "crush sleeve" is this necessary to replace or should I just plan on reusing whats in there right now depending on whether the condition of it is ok or not? Second question I have is I've heard its crucial to make a mark of some sort before I attempt to take the nut of the pinion so I can show where i need to tighten it back down upon re-installing but would like to hear some feeback on how others did it. My last question is what tool would you suggest me using when taking out the old seal? Thanks!!
Old 06-26-2006, 12:00 AM
REDWS6ROCKET's Avatar
fairly simple take the driveshaft loose, mark with a chisel were your nut lines up with your pinion. remove the nut and yoke. get a screwdriver and hammer and knock in the outer edge of the seal until you can remove it. install the new seal and yoke. tighten nut down to were you marked it at.
Old 06-26-2006, 01:32 AM
angel71rs's Avatar
A lot of the times you can do that and get away with it. But the crush sleeve is actually a spring, and once crushed, will not load properly if reused. Mine is leaking too, not too bad yet, but I'm going to do it some time in the fall.
Problem is, crushing that sleeve sucks, it's very touchy when you are trying to get the proper reading on the inch/pound dial torque wrench, just a hair too much and it will shoot past the range, needs a new sleeve if it's going to be done right. Sleeve concept itself is problematic. They can put too much load on the bearings and burn them up, not enough and that can cause problems too. So I'm thinking of using a solid spacer, never used one before, but I might give it a try.
Removing the seal itself is easy, just use a screwdriver.
Old 06-26-2006, 01:58 AM
2002_Z28_Six_Speed's Avatar
Mine actually had a solid spacer so maybe it wasn't the first time someone blew it up. I wouldn't do it unless you were replacing gears or had a shop with full complement of tools.
Old 06-26-2006, 09:18 AM
jmm98LS1's Avatar
Even though it's not the right way to do it, I've always done it this way and never had any problems doing so.
Old 06-26-2006, 11:21 AM
angel71rs's Avatar
I have the tools, have done many R&P changes. I hate crush sleeves, so figure I'd try a solid. I read an article years ago on Tom Watt's (Tom's Differentials) method of doing an R&P on a 12 bolt. He didn't use anything at all, no crush sleeve or spacer! He just torques the nut till he gets the proper bearing preload.
So the next gear swap I did, I tried this method. It was the 8.5 10 bolt on my 71. It only took ~ 90 ft/lbs to get to the recommended preload for new bearings. I was a little nervous about maybe the torque being a little low, so I added a small tack with my MIG. That was ~ 10 years ago with more than a few runs at the track with zero problems.
Don't want to try it on the 98's diff. Weak sauce 7.5. Besides, I think I read somewhere that the solid spacer helps support the bearings better.
Old 06-27-2006, 08:27 PM
komik's Avatar
I changed the pinion seal on mine a few months back. I remember it being easy, I just don't remember how I did it.
