Need help with a 2.8L Corsica
Not too sure what forum to post this in so ill try here.
i have a '88 Corsica that keeps my Formula out of the rain which its not doing its job right now.
the car will run at times, but every now and then it will get a slight miss that gets worse causing the car to stall out.
my guess is the crank position sensor, is there a way to test it? also where is it located at on these motors?
Thanks
Thanks
Administrator
There is no place for this honestly since this is a tech-based LS1 site. The Lounge would
have been an appropriate spot in the past. However, we've spun-off a new website
and closed down the Lounge. Where are you located? Perhaps this belongs in the
forum pertaining to your geographical area.
