Manual headlight control stripped!
Old 07-23-2006, 10:44 AM
rorad's Avatar
Default Manual headlight control stripped!
I need help! The gear is stripped on one of our headlights but I found when I went to repair it that the manual headlight control is stripped so I can't raise the headlight manaully. How can I do this so I can replace the motor assembly? Thanks!
Old 07-23-2006, 11:54 AM
taintedmeat's Avatar
Maybe come in from underneath and take the nut off that holds the arm to the motor. Then you can just pull up on it.
