low coolant light
low coolant light
I filled up today and got in the car and turned it on. And the low coolant light came on. I poped the hood and checked the hoses,water pump, tb bypass and i did not see a leak. I checked the over fill stick meter thing and it looked normal under hot condition. Should I wait for the car to cool down and add some coolant through the radiator cap? or add it through the overfill. Need help asap please.
ps when i had my LT1 Z28 i know the sensor crapped out, could that be the same story? or just add some coolant and see if it goes away.
yay! another low coolant thread!...low coolant sensors in these cars are almost definately gonna crap out. there are so many threads on low coolant lights and im almost pos. its either dirty, which you can clean, or its bad. just unplug it and ziptie it to something...ezfix
no prob, like i said if you clean it and it doesnt do the trick just unplug it until you can replace it or just leave it off. i routinely check my fluids anyway so its not that important to me...
my car only has 30000 miles on it when I had to replace mine, thats just about the only thing you can do. Good thing is that it only takes 10 minutes to do it!
i have the same problem and that little red light you kinda get used to after a while. =P
i think im going to keep mine on to trip out the ricers that have their dash lit up like a christmas tree, so they think im not "stock"
lol, i bought the sensor today, how do i go about changing it? any articles?
if i have to take the battery out, will it reset my radio presets? and my key fobs?
