a/c problems!!
a/c problems!!
well ive had my 98 z for bout a year and ive never noticed about on how the ac works and well i turned it on and it only throws out air to the bottom like towards ur feet,even when i put the thing and the front air it still comes out to the bottom, do i need free on? does anyone have the same problem? please help me with any info
That is the classic symptom of a disconnected vacuum line. Check the vacuum lines where they come together at the back of the intake manifold.... I believe there is a 3-way junction. This is a common problem, especially for f-bods that have had the intake manifold off for one reason or another. (modded)
You may also want to replace the diaphram/valve that controls the vents. I have had to replac3e mine a couple of times and I know I'm not the only one.
Check here
https://ls1tech.com/forums/showthrea...light=diaphram
for location, part #, etc.
Check here
