A.C. Stop Blowing HELP
Old 08-23-2006, 05:21 PM
F250POWERSMOKER's Avatar
Exclamation A.C. Stop Blowing HELP
One Of My Work Trucks Is A 2005 Chevy Ext Cab Truck
The Fan For The A.c. Does Not Blow Anymore
Anybody With Tips On A Quick Fix Or How To Replace The Part That Needs To Be Replaced Thanks For Any Help...
Old 08-23-2006, 05:35 PM
2001NBMZ28's Avatar
Blower motor? Does it work with the AC off/in heat mode?
Old 08-24-2006, 10:48 AM
No blower with the heater on either
Old 08-24-2006, 03:54 PM
navy02ws6's Avatar
Probably the blower motor...I'd check the fuse first.
Old 08-24-2006, 05:53 PM
2001NBMZ28's Avatar
If it's like the f-bodies it's just a 2 wire connector on the motor, pull the connector and see if it's getting power with the fan turned on...should eliminate the motor or switch.
Old 08-24-2006, 05:55 PM
97PredatorTA's Avatar
Yeah check fuses and wires first. On my Blazer I was working on it one day and bump the blower motor wire loose somehow. I had no idea why it wasn't blowing until my dad happened to see that the wire was loose.
