Any of you changed your front wheel bearing hubs?
Mine are starting to make a noise after about 35 MPH. And it seems that each week it just gets louder and louder. Very annoying. The new assembly for each side runs around 115 bucks. Couldn't I just keep the hub and just get new bearings for inside? Anyone out there come across this?
It is definately coming from the front end. I removed the four bolts and unplugged the sensor but I still can not get the damn hub assembly out. I tryed a rubber mallet and some PB Blaster, still won't budge. Should I just go with the BFH method as long as I have new assemblies?
i changed mine only to find the noise was still there. it was the metal thing that goes between the brake pad and cliper. to make **** worse i droped and broke the old one as i took it out. so i couldnt change the hub back out
