headlights dim when car shifts?
Old 12-13-2006, 04:24 PM
chevygirl's Avatar
Default headlights dim when car shifts?
My car lights dim for a second when the car shift. Like when it has a heavy load on it at that second. Anyone have any ideas?
Old 12-13-2006, 06:23 PM
staringback05's Avatar
check what the load is from the alt....dont trust the dash gauge....
Old 12-13-2006, 06:26 PM
Closed ex-Sponsor Account
autotrix's Avatar
Could have a bad connection somewhere under the hood. Usually a dim light screams that there is a bad ground connection; with it happening while it shifts makes me think that the engine movement causes the connection to move.
Old 12-13-2006, 06:33 PM
if its a connection id go with the little wire coming off the alt.
Old 12-14-2006, 09:49 AM
chevygirl's Avatar
Thanks, I will check the alt ground. I have a slight lose of power this week too. It happened after my tank was low and I filled up with Amoco 93 octane. Then the car drove differently. It was not as peppy. I think I might have got some bad gas but this light thing and my new battery keeps having white powder on it even after I clean it and neutralize it with the battery cleaner. I thought I might have a power problem instead of a gas problem. Car was doing great though until the low fuel and added full tank.
Old 12-16-2006, 08:07 PM
joshp14's Avatar
My car does that sometimes when its cold out....headlights dim just a little when I shift. I believe its because you are dropping the RPM when you let off the gas. I tested my alternator and it was fine. I wouldnt worry about it unless they are dimming significantly.
