turn signal lever replacement
Old 12-19-2006, 05:00 PM
bww3588's Avatar
Default turn signal lever replacement
i was wondering, since GM and their cheap wisdom decided that a multi function cruise switch from the 80's was sufficient on our cars but not any other vehicle if a newer one from say an S10 or somthing like that could be used in place of it. its so cheap and stupid it pisses me off. anyone attemped this?
Old 12-19-2006, 06:25 PM
gnomee's Avatar
I think most any newer one would be attached to a different style steering column so it probably won't work.
Old 12-19-2006, 07:07 PM
LS1TECH Sponsor
badpewter-z's Avatar
it may feel cheap and flimsy but is alot more reliable then the newer ones
it could be done but wont look right and probbly not be able to keep the auto-cancel feature
Old 12-20-2006, 12:40 AM
bww3588's Avatar
auto cancel?
Old 12-20-2006, 06:57 AM
LS1TECH Sponsor
yea, how it shuts off after you make the turn
Old 01-01-2007, 03:55 AM
ROB2000's Avatar
anybody replaced one with a stock one? mine completely broke. someone had their lights off one night, so i flashed them the highs, and the freaking thing stuck in high, and i had to force it back, and it bent. so i lived without high beams, after awhile one signal would blink, one would not, so i moved the arm manually. and it finally just popped loose after awhile and now i have no turns. i got the wipers to work, but the assembly just hangs. and it looks like a pita to replace.
