Gas gauge problem?
Gas gauge problem?
Gas gauge was a little over 3/4, i start the car and now it seems pinned at full when the car is running, i have 50miles in this tank and it is not moving, is something stuck in the tank maybe? It should be a tick over 3/4 by now. Should I give it some time? (doesn't seem normal)
dude mine does the same thing...but like i drive around and it goes down just a little bit, than the next morning or whenever i turn my car on again it shows that i have a lot lower gas than i did when i turned the car off. It really pisses me off
Sounds like your fuel sending unit is going out. Same thing happened in my Camaro. Bad thing is you can just get the sending unit by itself. You have to purchase a fuel pump assembly as a whole. At least that what what I was told when I was calling GM dealers from the shop. Wholesale was around $300 so if you work at a shop or know someone who can order parts see if they can order you one. If not it can be up to $600.
