Removing door on 4th get Fbody
Old 12-31-2006, 02:56 AM
jfman's Avatar
Default Removing door on 4th get Fbody
Where is the plug for the wiring of the door ? Is it in the door or inside the car ? I pulled the rubber boot but I dont see a plug. I tried to feel arounf with my finger but I cant find the connector ?
Old 12-31-2006, 11:19 AM
FLA02TA's Avatar
You can pull the kick panel out (4 screws along the seat), and the under-side of the dash (two plastic push pins and a metal clip in the back for passenger side).
That accesses the vehicle side.
As far as the door side, you'll have to pop the window/lock panel, unplug them (as well as mirror control for driver side), pull the lock lever off and pull 4 screws to pull the panel off. Disconnect the speakers, and set the panel aside.
There's basically a rubber tube that feeds the wires to each exposed side.
Old 12-31-2006, 07:15 PM
jfman's Avatar
I know how to do that but I has hoping to find out where the plug is so I dont take anything apart just to see.
A does anyone know where the plug is ?
Old 12-31-2006, 09:39 PM
88zukon36s's Avatar
When i removed my door i just unpluged everything inside the door and slid the wires out. Then i removed the door.
Old 01-01-2007, 03:07 AM
jfman's Avatar
So there are no connectors ? I have to unplug all the accesories inside the door ?
Old 01-01-2007, 08:22 AM
01WS6/tamu's Avatar
There are no connectors to separate the crossbody harness from the door harness you have to remove the wires from the door then feed them through the hole the grommet goes into.
Old 01-01-2007, 01:17 PM
jfman's Avatar
Only from GM...
