Need Help! What does this mean?
Old 12-31-2006, 06:45 PM
99Transamls1's Avatar
Default Need Help! What does this mean?
I got into my car this morning and started it up and the only gauges working were my oil battery and rpm my lights that are on are check gauges, absinop, service vechicle, airbag, service engine soon was on anyways because I havent got my back 02's deleted(but started blinking a couple of times). I started driving it and it started working, then it stopped again. I pulled over turned my car off and re started it and everything was working again a few minutes later it stopped. Now it has stopped and will not work. I the fuses in the driver door and the two boxes under the hood and no fuses are blown. Does anyone know what this means?
Old 01-01-2007, 12:40 AM
now everything is still not working but my check engine light is off and my alarm will not activate but goes off periodically and when I takes my keys out and radio will not turn its self off. Damn I dont know what is wrong
Old 01-01-2007, 09:26 AM
well i got in my car this morning and it wouldn't start so i jump started it and when i turn the ignition off and took my key out it was still running. I had to put my key back in and turn it on and back off for it to die.
Old 01-02-2007, 09:43 AM
thunderstruck's Avatar
most likely your battery is not holding a charge
Old 01-02-2007, 06:12 PM
well i bought a new battery and a new ignition relay and it still is doing the same thing so i guess the next thing to buy is going to be a ignition switch.
