Ugh, spark plugs
Ugh, spark plugs
So, I got the 4 on the drivers side no prob, then went to work on the passenger side, my god what a PITA. Sucks too, cause I didn't complete the job. I gouged the top boot on the #2 plug wire, so had to replace my nice MSD wire with a Delco(Cause I only wanted to buy one, not all 8). I also messed up plug 2. Didn't completely shear the top off, but apparently broke it enough to where it wasnt firing. I was trying to use 2 wrech extensions and a u-joint. But since I couldn't even get #2 out, I gave up on the other three as well. So I had to drive it to my mechanic with one hell of a miss(possibly even dead cyl 2) and i'm paying out the *** to get those 4 plugs done, $93. Next time I go to change them, i'll prolly try to find a local member who is good at it to help me.
LS1Tech Administrator
Received 1,493 Likes
Your best bet is to use some antiseize on the plug threads and dielectric grease for the wire boots. This will make the next change much easier.
1998, and I dunno how many miles since the last change, but car has just over 51k, and the plugs i pulled were bosch platinum+4, so not factory. I replaced them with NGK TR55GP.
On my '98, I just pull the AIR tube off the manifold and push it up/over, move the throttle cables out of the way (ASR only cars), pull my STB off, and work around the ign. coils. Seems easier than trying to pull individual coils.
I use a combo of spark plug socket, slim-line ratchet, short universal extenstion wrapped with electrical tape, and climbing on top of the motor with my stomach facing the air lid. This seems to get me down to that #8 plug. It's not fun, but it's the best method I've found for a '98 car.
Does anyone with a '98 actually pull the individual coils off the valvecover on the passenger side to swap plugs?
I did it for #8 once because all the 99-up guys always laud how much easier that makes the job, but, honestly, it was just like you said "more trouble than it's worth."
It did give me a little more leverage on the ratchet, but overall it took about as long to take the coil pack off as it did to get to the plug normally
Originally Posted by BLKWS.6
I have 77K miles and its running fine. I know I should think about it but I will be niave and chant my matra "GM said fine for 100K."
I have a 98 and I didn't find it too difficult, just took me over an hour.
On passenger side I disassembled the air hose and pushed them out of the way, I disconnect the EGR, I remove the rear coil packs only. On the drivers side, just unplug the temp sensor and disconnect the air tube. Plenty of space on this side.
I use a swivel wrench with an offset handle and standard spark plug socket. It's all in the tools you use I think. A standard socket wrench will not work at the angles those plugs are at. Add in the lack of space on the passenger side, the blind 8 plug and you got hell going on there. The hardest plug I think is number 8 due to the fact you can pretty much only reach it by going over where the coils are (hence removing the rear coil packs) and from behind the engine. With stock headers, underneath is not an option. Also when torquing the plugs, do not overtorque.
