Heater question?
Old 02-01-2007, 11:38 PM
musclehead's Avatar
Default Heater question?
My heater won't blow any heat. Don't know why can anyone help me? Where should I start first?
Old 02-01-2007, 11:52 PM
seawolf18's Avatar
check your thermostat to see if its stuck open.
Old 02-02-2007, 06:34 PM
Camaro_Z28's Avatar
Check to see if the heater core is plugged, run the car up to operating temp then grab the heater hoses, they will tell you alot. If they are both hot its an issue with air distribution such as a broken heater control cable or blend door. If one is cold, One is hot then check for a plugged heater core. And if they are both cold then I'd be looking towards a t-stat or not likely but maybe a waterpump. Hope that helps.
Old 02-02-2007, 09:10 PM
XpEdItIoUs's Avatar
Your heater core operates from engine coolant make sure you got no air in your cooling system.
