Motor mounts ques
Old 02-06-2007, 10:48 PM
hardtopz28's Avatar
Default Motor mounts ques
What is the easiest way to install these anyhelp will be greatly appreciated
Old 02-06-2007, 10:54 PM
connexion2005's Avatar
https://ls1tech.com/forums/showthrea...ht=mount+write
This is a good example of how to get it done...
Josh
I priced the labor and its about $200 dollars labor at most professional shops. Almost worth the headache even if you are a do it your selfer like I am. However, if you are going to do headers, then definetley consider doing it yourself. If not, then you have options...
Old 02-06-2007, 11:06 PM
staringback05's Avatar
if you have any internal plans or want to add anything....just pull the motor and add them in to
