lossing power
Old 02-16-2007, 09:42 AM
stdjsw311's Avatar
Default lossing power
ok i was driving home last night and noticed that my check gauges light came on. well...the ampers looked a lil low. so no big deal. well i started home(15miles) i get about halfway home and my abs and my asr light come on. the volts r about 11 at this point. i get about 2 miles from my house and then the service engine light comes on and the air bag too. my guages stop working all go to zero and read nothing. the radio goes off. i pull into the driveway kill it and it wont restart. so i wake up this morning 26 degrees out and the car starts right up no problems volts are up a lil high but everything else is great! so what gives what happend where would i start to look and what would cause it to do that????
Old 02-16-2007, 09:50 AM
98Camarod's Avatar
Possible alternator failure? Maybe its a bad ground somewhere. Check and clean the grounds and see if that helps. I couldnt do 26 degrees.....that sucks. Sounds like you are in an area that gets snow so there could be rust on one of the grounds.
Old 02-16-2007, 09:54 AM
stdjsw311's Avatar
haha actually i live in texas just north of houston. yeah i am going clean some grounds tonight. i wonder if my powersteering fluid could be leaking down on the alternator.
Old 02-16-2007, 10:54 AM
lsx24's Avatar
Sounds like an alternator or battery issue. Both could have caused the symptoms you describe. You can take it to a repair shop and they can test your alternator and battery. Also a good idea to clean the terminals for corrosion.
Old 02-16-2007, 02:46 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
gremlins.
Old 02-16-2007, 02:47 PM
staringback05's Avatar
ill put money on this.........theres a small wire leading to the top of your alt. its the sensor that in effect keeps your battery charged from the alt.....its either broke or has come lose....another GM issue
Old 02-16-2007, 03:27 PM
stdjsw311's Avatar
ok i will check that. i started it up a few mins ago and it said 10 volts or so.
