engine fuse
Saw your post on the MAF - you need to look at the pins/wiring for any shorts. Another common thing that'll blow the ENG SEN fuse is one of your 02 sensor wires is burned through/arcing on the header somewhere since you have LTs, they're on the same circuit.
damn ur right bro i already took it to a shop i always go to and there gonna take a look at it i did have a 02 sensor burnt to the header but i replace it and also i kept the driver side in still cuz it was still good!!! hopefully everythings ok!!
