Coolant Disapeared?
Old 04-11-2007, 03:46 PM
JD_Z28's Avatar
Default Coolant Disapeared?
My mods are in my sig. I noticed the other day my car started overheating and I checked the fluid and it was empty. What really confuses me is that I filled it up about 2 months before that. I haven't noticed any white mist from the tail pipe or any major leaks.
The car seems to run fine. what do you guys think is going on? Should I check the oil to see if theres any sign of coolant in the system.
Old 04-11-2007, 03:52 PM
brad8266's Avatar
From your other thread:
Originally Posted by JD_Z28
My heater dosen't work. If its getting into the heater core how would I be able to tell?
Well with a dry system your heat wont work, you can tell if its leaking from there by checking the passenger floor area since the heater core is located right up in that area, it it was leaking the floor would usually be wet.
Old 04-11-2007, 03:53 PM
JD_Z28's Avatar
I will check. Thank You Sir.
