Question about the cruise control and more..
On my stock radio, some of the preset numbers don't light up as well as the AM/FM, CD, etc. Is this a blown fuse or something else. If its the fuse, where is that fuse located?
Also my cruise control no longer works, i checked and made sure everything was hooked up, and i also looked at the the AC Cruise fuse in the fuse box under the hood and it was fine. Anyone have any ideas? thanks?
On the driverside frame below the box for the air cleaner on the inside of the rail there is a little black wire coming out of the harness. I would check that and clean up its connection.
