squeaking on left turns. help
OK so i own a 99 trans am. The car makes a creeking noise when turning to left. moving or not. but when i turn to the right no noise. If I am not moving and i turn it slowy it will click/creak. very hard to explain how it sounds. what could be making this sound and what do i need to do to replace it?
ok so i got under the car, and the tie rod boots are def bad. ill fix those soon. But it doesnt sound like a rank in pinion or balll joint or anything more that just some dry spots that need to be lubed?
I just gave you the most obvious things. I cant hear it, only you can. Have someone turn the wheel and you get under there and listen. Bring a can of wd-40 and hit parts as they move them to see if you can norrow it down or find it.
