Help!!!!!!!!!!
Help!!!!!!!!!!
Im supposed to get my 98z inspected tomorrow morning. Long story short just got the car back from getting the dents fixed, let is sit and maybe an hour later i back it down the driveway wash her off, dry it and then i go to start the car and she wont crank????? I am getting power to the car but when i go and turn the key the starter wont crank nothing dims when i turn the key or anything so whats the deal? Any help will be greatly appreciated. thanks in advance.
__________________
__________________
The starter is history???? Check the starter fuse under the hood??? Use one of the other fuses in there to check, pop out the starter fuse and put the other one in and try it. You could than check for corrosion build-up on the cable that goes to the starter.
