Can't find misfire, details inside
Bone stock 99 WS6. Car threw P0307 after a bad shift and over-rev. Prior to knowing it had been overrevved here's what was done
Changed the plug - it was white like the car is lean
Changed the wire -still not fixed
Swapped the coil to another cylinder - code stayed on #7
Found out the car had fallen victim the the infamous 2-3-2 shift at the track and the misfire showed up right after the run.
Pulled out the pushrods, they aren't bent. Swapped them for two other pushrods I had available anyways. Not fixed.
Decided to check out the injectors and this is where it gets wierd. Engine running, being held at 2000 rpm, I pulled the plug off of the #1 injector to see how much it stumbled, put it back on and pulled the plug off of the #7 injector and nothing happened, no stumble like it did with the one that was known to be functioning. So, swapped the two injectors and the code still stayed on #7. Rechecked the stumble by pulling plugs off of injectors and the same thing happened even after swapping the injectors, #7 was still the problem.
What's next?
What's next?
Originally Posted by keliente
Could the lifter(s)/valves on #7 perhaps have thrown in the towel to the dreaded misshift? Over-rev/bad shift just screams valvetrain issue, especially since it came on right after.
So are we looking at a comp/leakdown test and then using the results to decide if we're pulling the head on that side? If it passes we'll look into something obscure like the cat or O2 sensor?
That's why I said obscure, lol. The comp test goes down tomorrow, I'll update when we know something. For once the LS1 pushrods were just a little too strong. . .
