Window Motor Replacement
I have a 95 T/A and my passenger window is going up and down very slow, and sometimes it will even stop going up. I replaced it about 2 years ago with one from Advaced Auto Parts. I was wondering if anyone has done the WWW.autotrix.NET fix and if it actually works ,or should I just go to AutoZone and get a new motor?
I just did my passenger side. It's nice knowing that it closes all the way instead of finding out later it didn't close.
The shoebox guide is good, but I have to admit the LS1 doors seem to have changed the placement of the rivets ever so slightly.
I also had a frustrating time getting the new screws/nuts in. It's no wonder you have to use locktite, if you don't drill a large enough hole a screwdriver or socket wrench is a tough fit.
When I did mine I used a dremel instead of a drill, so instead of little holes I cut squares so I could get my hands in there better. But I did have dust all over my car.
