Break Pad replacement
Old 05-29-2007, 12:29 PM
koz28's Avatar
Default Break Pad replacement
Anyone have detailed instructions on how to replace brake pads on a 1998 Z28? Like the instructions we have on here for window motor replacement is really detailed with pictures. Any chance we have same type thing for Brake Pad replacement?
Also I am considering getting Kumho Ecsta tires. Any opinions on these?
Thank you
Old 05-29-2007, 12:55 PM
Starion's Avatar
Default Yep
www.installuniversity.com
Check under the brake section.
Old 05-29-2007, 07:17 PM
slvr98camaro's Avatar
its REALLY easy, you take the tire off, take the two bolts holding the caliper off, take the caliper off, and put it somewhere so the hose isnt getting stretched, the pads will slide out, slide the new pads in, then get a vice and push the pistons in then put the caliper back in place, and re tighten the bolts.
