ignition lock cylinder
Hey all, have a quick question. I picked up a little v6 car for a project car but the owners have lost the keys. I went to the dealership yesterday and had a new set cut but the ignition key did not work. Door key worked great. I need to get the steering wheel unlocked so I can load the car on a trailer and get it home. I'm wanting to know if I simply removing the ignition lock cylinder, can I turn the steering wheel? I'm not worried about the car starting, I just need to be able to steer it.
Thanks for any advice you can give!
to remove the ignition lock cylinder u will need to pull the stering wheel off, so that u can pull the bolt out so u can slide the cylinder out and u should be able to start it with out it. unless the secerty goes off. but yeah u will have to pull the wheel to get the cylinder out.
Dealer cut keys
befor you go that far put the new key in the car and tap on it with something.
last saterday I had to get a new key made for my TA the key they made me worked but not till after I got a new switch installed.......
