a/c question
a/c question
I figured my freon was low because the air stopped blowing cold. I bought a kit with a gauge and the psi in the a/c system says danger. It has way too much pressure in the system. Anyone know what I need to replace to get the a/c working again? It's hot as hell in south florida right now and I am dying. Thanks in advance
Is it reading that high with the compressor running, or just when you put the gauge on? Thinking you might be reading the static pressure. Static you'll see around 100 psi depending on the ambient air temp.
