Need Help
It should be on the passenger side near the accumulator, aluminum canister mounted to passenger fender. the port should be covered by a black plastic cap that you have to unscrew off. Just for info, high side is right to the passenger side of the
radiator also with a black plastic cap covering it.
hope this helps
hope this helps
hope this helps
hope this helps
I see the one on the passenger side of the radiator. The connection of the recharge kit won't fit that, but the only other port I see is actually on the accumulator. I've never seen it ON the accumulator before so that kind of confused me a bit. I'm assuming that that is the low side since the connection of the recharge kit will fit it.
Thanks for your help! It's been HOT in Atlanta lately!
