front and back blinkers dont work!
Old 08-17-2007, 11:25 AM
93redBIRDman's Avatar
Default front and back blinkers dont work!
Randomly today, my front and back blinkers stopped working! Even the interior blinker lights on my dash dont work when I try to signal left or right. Is there a fuse or relay that went bad or what??
Old 08-17-2007, 12:28 PM
subhumanzz's Avatar
if one of the two ( front or back ) turn signals blow the opposite one wont work either. check your bulbs im sure one is just blown out. easy fix.
Old 08-17-2007, 12:49 PM
yea but all 4 don't work. I'm thinking its a fuse or relay somewhere that blew because the odds of a front AND rear bulb going out at the same exact time is low. AND when I try to blinker, even the interior blinker lights on the dash don't work. They'll only flash when i do the hazards (but the blinkers still wont flash when i do the hazards)
Old 08-17-2007, 01:37 PM
01WS6/tamu's Avatar
Out of blinker fluid fill'er up and you should be good to go. After that check for fire into the turn signal switch at the base of the column. Check to see if the brake lights are working. If not it is for sure a bad turn signal switch. Check for 12v out of the column on the dark green and yellow wires with the switch in left and right turn. I
Old 08-17-2007, 06:27 PM
^ lol
Old 08-17-2007, 07:12 PM
ipdking711's Avatar
most cars if there is an issue with the hazard light switch turn signals wont work...just food for thought
