help with misfire
Old 09-16-2007, 05:44 PM
02camarols1's Avatar
Default help with misfire
i have a 02 camaro ss and ive had a misfire problem i cant figure out. it throws a
p0357 ignition coil 7 circuit malfunction and a random misfire code. have replaced the coil and plugs and wires. need help figuring this one out.
Old 09-16-2007, 07:03 PM
blownta00's Avatar
thats wierd man ill do so research for ya
Old 09-16-2007, 07:09 PM
thanks anything u can find will be a big help
Old 09-16-2007, 07:18 PM
caddobass's Avatar
My 2002 SS has been giving me a fit also. I've changed two coils, two O2 sensors, & the plugs and wires. I got the codes to go away and now the car starts and runs fine. But when I cut the engine off and restart it it has a hesitation or stumble when I step on the gas ( this happens when car is hot on restarts, not on a cold start ). Let me know what you find.
Old 09-16-2007, 07:29 PM
ive replaced the o2 sensors too but mine does it all the time. it does it from a cold start, a restart and going down the road. if i jump on the gas it will stop for a minute but then will start to act up again.
Old 09-16-2007, 09:52 PM
GMRL's Avatar
Is the harness/wires/connectors going to the coil ok?
Old 09-17-2007, 12:37 PM
everything looked ok when i looked at it sunday but it was kinda dark so i will look again today
Old 09-17-2007, 06:28 PM
checked out all of the connections and everything looked good. the plug wire is on and the connector to the coil pack is on
Old 09-17-2007, 07:08 PM
1999Transamman's Avatar
Im having the same issue with my T/A. I thought it might be a bad ground connection so i checked the ground on the coil and connector, no go, then i swapped coils, nothing, now on a note everytime i do something it goes away then comes back. it doesnt throw the ses light, but it does show on my scan tool, i clear it and it comes back. I think it might be a corroded connection.
