those with frequent o2/heater codes
Old 10-09-2007, 08:41 PM
tc3
tc3's Avatar
Default those with frequent o2/heater codes
Just wanted to inform people of this:
For a very long while i have always been getting slow switching and heater performance codes for both o2 sensors(front) and they are both relativly new. Well i noticed they mainly are thrown when in traffic and i am at lower rpms for a while.
Welllll i got a newer 5 wire maf(screened) to replace my descreened stocker...
After some programing, not only do i get the throttle response back off idle, i havnt thrown a code for an o2 since. And this was 2 months ago on a dailly driver....
Soooo moral of the story is if your having o2 codes, a descreened maf may be the culprit.... im guessing cause the inaccurate readings with low airflow causing the afr to go rich and make exhaust temps colder.
Old 10-10-2007, 10:41 PM
2000Z28ls1's Avatar
Mhh that might be a good idea how much does a New MAF run like 100-200 bucks?
Old 10-11-2007, 10:36 PM
tc3
tc3's Avatar
yea something like that, if you search around there should be a company that makes the new model(5 wire) maf compatable with the ls1 tune so you dont have to waist money on updating your maf with efilive or hptuners or w/e
Old 10-13-2007, 06:16 PM
motownZ's Avatar
soo you said the lights tuned off from that. i had the PO155 code for 2 days then went off for good. but then after 2 months checked again it was still there just no SES light. double check that is corrected it.
Old 10-14-2007, 09:58 PM
tc3
tc3's Avatar
P0155 is a heater performace code. It is an emessions related and will always take 2 consecutive trips to trigger the s.e.s light. If conditions meet for it to trip once it will throw a code but not s.e.s light...
