My fuel pump is taking a crap help!
Old 10-14-2007, 11:52 AM
Zero30's Avatar
Default My fuel pump is taking a crap help!
hey guys maybe someone can help me. I took my car to MTI last weekend and put it on the dyno and midway through the pull car seemed very weak. The tuner told me my fuel pump was starting to give. Anyway the problem has been getting worse on a cold start the car surges bad and dies. I then took it to autozone and scanned it the code PO327 I think it may be my knock sensor but the fuel pump crapping out may be the culprit. Do you guys think it is the fuel pump, knock sensor or both. And what fuel pump should i buy as a replacement. Thanks
Old 10-14-2007, 01:12 PM
2001NBMZ28's Avatar
Have you already tried replacing the fuel filter?
