Only Hi Beams Work?
Old 10-16-2007, 08:36 PM
arality's Avatar
Default Only Hi Beams Work?
I have a 99 Firebird and for some reason only the hi beams work. The fog lights or regular lights don't turn on. The switch is working fine because the lights raise and lower. I am really stumped
Thanks in advance for your help guys!
Old 10-16-2007, 09:29 PM
SparkyJJO's Avatar
fuse?
Or all the bulbs burned out? Silly sounding I know but my bro thought his fogs on his car were bad until he decided to try a new set of bulbs lol.
Old 10-16-2007, 09:34 PM
arality's Avatar
I am going to try a new bulb as soon as I can get to the store. The funny thing is though that both of them and, the fog lights went out all at the same time. As far as the fuse I assumed the headlights (Hi and low) beams were all on the same fuse. Will definatly need to go take a look at that thxs
Old 10-16-2007, 11:34 PM
conde'strans's Avatar
I was having that problem a while back so I took it to a local electrical shop and it ended up being not enough ground. the guy just hooked up a little wire, therefore, adding a better ground and WALA! cost me $20
Old 10-17-2007, 10:20 AM
Copy & Paste Moderator
VIP1's Avatar
Which means that there is a broken ground somewhere that was not fixed.
Old 10-24-2007, 11:49 AM
moserman's Avatar
check the relays under the hood
