360 degree electrode sparkplugs i.e. Torquemaster and Halo. Are they any good??
Has anyboby out these has used any of these 360 degree electrode plugs like the Torquemaster and the Halo???
Are they any good??
If they are, how does their performance compare to the other trick plugs like platinum and iridium????
Are they any good??
the idea of a spark plug is to have several concentrated (hot) sparks to ignite the fuel, not a bunch is crappy (cooler) sparks jumping from the electrode to several different spots, which in turn will cause those spots to foul and eventually only having one spark
they are not a good idea.. they shroud the spark more than anything else. in fact the position of the electrode is soo important there are guys that index the plugs and use small shims to set the electrode so the incoming fuel/air charge is open to the spark cleanly without the electrode being in the path.
