2002 Camaro Window Motor Replacement Help!!!
I have purchased a new driver side window motor replacement, and I need some help/advice on the install. Any help from those who have done this install would be greatly appreciated!!!!
Thanks,
Brad
Thanks,
Brad
Finding the rivets/drilling is the hardest part. I printed his enlarged pic and brought it out to the car which made them easier to locate. If you're not the original owner you may even find it's been replaced before and already drilled.
Yea, that seems to be the hardest part, going off of the pics and all. Well, never the less, Even if it turns out looking like a gun fight, it'll save be $90.00 in labor for the window replacement!!!
Thanks again!
Brad
Thanks again!
Brad
Follow the pictures and it will be easy. Also mine had been replaced before in my 120k mile Formula but they did not drill out the holes yet go from behind with bolts. It ended up easy once I drilled out the holes. Good luck!
