trouble code...how to fix, will it effect my performance
Old 04-17-2008, 09:27 PM
V8bamf's Avatar
Default trouble code...how to fix, will it effect my performance
P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) Pulling this code what is wrong and will it be hard to fix?
Old 04-17-2008, 09:37 PM
1FST-Z's Avatar
Your front left 02 sensor just bit the dust. You running extensions?
Old 04-17-2008, 09:42 PM
V8bamf's Avatar
i dunno. i have headers and i had a guy fix them once. how much is a replacement? is it hard to fix?
Old 04-17-2008, 09:52 PM
1FST-Z's Avatar
Hmm. Get underneath your car and see if your O2 sensors are just one super long wire that's all zip-tied up, or if it's "2" wires that are connected together with a plug. See, the location of the 02 sensor bung is way farther back on longtube headers in comparison to the stock exhaust manifold. Hence, one of two things are required:
1) You've got the 02 extensions to make it reach properly, or
2) You've got the Corvette C5 rears in there which are super long and reach properly without extensions.
If it turns out that you've got the extensions, consider visiting ws6store.com. Type "Bosch" in the search box. You will find the two products that come up are the OEM style 02 sensors, and the C5 rear sensors. Read the paragraph description on the C5 sensors...explains pretty much what I just told ya.
