New water pump/T stat questions.
Old 04-22-2008, 06:47 PM
SSNISTR's Avatar
Default New water pump/T stat questions.
My water pump seems to be starting to drip a little, so before it gets any worse I wanna swap it out. It is the stock 60K pump. Now, a few questions. What pump should I get? A more costly GM one, or will a new Advance Auto Parts one with a warranty be just as good? Also, I have a 160 T stat. I have been told this will NOT fit on the new water pump and I will have to buy a newer 160 T stat? Finally, and tips or tricks to get the bubbles out when I am done? Any advise will be great as I want to do this really soon.
Thanks!
Old 04-23-2008, 07:48 PM
SSNISTR's Avatar
Anyone?
Old 04-23-2008, 08:01 PM
Mr Incredible's Avatar
I don't know about the 160* t-stat. I kept the stock one when I changed my pump. I don't believe it, myself. The replacement pump will be the same as the old one, what fits one should fit the other.
I got a new water pump from the parts store rather than a rebuilt. I don't figure to need one real soon and I believe it to be a fair choice. I don't pay dealership prices unless it's on something I can't get anywhere else or the price diff isn't very big.
To purge the system of air:
-Fill the radiator, start the motor.
-increase idle and pour in more coolant as the level goes down.
-do this until the t-stat opens up. Continue. Watch the bubbles slow.
-when you about have it, shut off your motor and put the cap on.
-fill your overflow bottle about 3/4 full. Drive normally for a while, keeping an eye on the bottle. Refill to 3/4 every time you let it cool off. Run the heater wide open several times.
-When it stops needing refilled, you're done. Could take up to 150 miles.
-Check everything you removed/replaced while doing all this, and for a week or two after.
Old 04-24-2008, 11:32 AM
SSNISTR's Avatar
Thanks for the info on the install.
But, the LS1 style pump is not made by GM anymore....
I'm just tring to find out if say Autozone's in the old style or new?
Old 04-24-2008, 01:18 PM
MrEddie's Avatar
I got a new pump from gmpartsdirect.com You can shoot them an e-mail and they'll let you know the part number. The pump came with gasket and the thermostat attached. Go to ls1howto.com for pump removal/installation instructions.
Old 04-24-2008, 09:15 PM
SSNISTR's Avatar
Yes, but it is not a 160 stat.
You need to buy a LS2 stat, the 160 stats from the LS1 style pumps don't fit....
Old 04-24-2008, 09:19 PM
SparkyJJO's Avatar
What's so great about these 160 stats anyway?
