change front turn signals?
Old 04-23-2008, 08:34 PM
93cz28's Avatar
Default change front turn signals?
both my front turn signals are cracked and i need to replace them. how do i take out the old ones?and put new ones in?. also when changing my high/low beams, do i just pull them out?
thanks
by the way its a 93 camaro
Old 04-23-2008, 09:34 PM
TireSm0ke's Avatar
The bulbs go in through the socket behind the housing. Im assuming you mean the housing is cracked?
Old 04-24-2008, 01:16 AM
waldershrek's Avatar
The turn signals are WAY easier to get to if you take out the headlights.
Old 04-24-2008, 10:26 PM
93cz28's Avatar
what i need to change is the yellow parts, guess its called the housing.the bulbs are fine.so i have to take out the headlights to get to the turn signals?do i just yank out the front headlights or is there a way to do it like the fogs?
Old 04-25-2008, 01:26 PM
BTTM's Avatar
The housings are attached to the body with screws. I access them through the convenient openings that GM put under the vehicle; one on each side. Some, I guess take out the head lights and access it that way. I find it easier to just jack up the car.
Be careful tightning the screws. If you overtighten they will break.
