Searched, Coil replacement
Old 04-30-2008, 03:36 PM
Brickyard's Avatar
Default Searched, Coil replacement
I searched but was unable to find what I needed.
Is there an easier way that involves keeping my hands attached to my wrists to replace the third coil on the passenger side of the Ls1? I removed my STB, and still can't squeeze my big paw back there to undo the bottom bolt. Even with a ratcheting wrench I had no luck? Should I hire a two foot midget to do it? or is there something stupid I'm not doing?
Old 04-30-2008, 03:41 PM
billyb's Avatar
removed the coil bracket,
Old 04-30-2008, 04:02 PM
Brickyard's Avatar
I considered that, but without a pet monkey, I have no way to get the fourth wire back onto that coil.
Old 04-30-2008, 04:11 PM
billyb's Avatar
Default you can do it !!!!!!!!!!!!!!!!
i had the #8 coil go out, i removed the whole coil bracket and when you re-install put the coil wire on first then bolt it up, it'll take a little time (tight area ) but you'll get it , i did it twice, good luck .
Old 04-30-2008, 05:46 PM
staringback05's Avatar
to be honest man, your probably gonna bleed a little on the knuckles if you have been blessed to have the pointy bolts...you might want to replace those...number 8 is all about the wiggle...just wiggle it on until it clicks...
Old 04-30-2008, 06:52 PM
Brickyard's Avatar
Okay, so I figured out how to do this in 30 minutes.
Remove your frickin EGR and unbolt the air pipe. SOOO much more room. Took five minutes to get the bracket out, and back in.
WHOOP!
All frickin afternoon I let two bolts stop me from success...
Old 04-30-2008, 06:54 PM
never thought about the egr...havent had that in years
