replacing oil pan gasket
Old 05-15-2008, 04:18 PM
jorgez28's Avatar
Default replacing oil pan gasket
has anyone got this done at a dealer if so how much? It just looks to hard to do this on my own
Old 05-16-2008, 10:20 AM
jorgez28's Avatar
Anyone do this on their own?
Old 05-16-2008, 10:38 AM
67rsss's Avatar
Not all that hard to change the gasket. The hard part is getting to it! I don't know how hard it will be for you to lift the engine and slide the pan out, our LS1 is in a first gen. I believe you could do it though. Changing the gasket itelf is a couple minute job. Are you certain it is the pan gasket leaking and not a rear or front seal?
Old 05-16-2008, 11:50 AM
jorgez28's Avatar
might be the rear main is this hard to replace?
Old 05-16-2008, 12:04 PM
Reject's Avatar
gotta drop the tranny for the rear one
to drop the pan on the stock k you gota lower the k the three bolts at each end. and even then you gotta juggle the pan out tilted down. its a lot easier on a aftermarket k. just suspend the engine
