Help-speedo, tach, odometer, radio do not work
What could be the problem if my speedometer, tachometer,odometer dont work-The needles dont move at all and the odometer does not light up or show anything? All of the other gauges light up. Although the battery, water temp and fuel gauge do work. The radio does not turn on either and the power window switch and door lock switch does not work. Also my turn signals are acting up. it signals to the left really slow and when signaling right it just stays on. I checked the fuses in the engine bay. Are there any more elasewhere? what else could it be? Thanks for the help in advance.
Check the panel on the side of the dash. The turn signal problem is most likely a burnt out bulb. Does your interior lights work? If so, the radio problem is a fuse issue. I personally have never seen multiple gauges not work sequentially without having to replace the cluster. Did you hook up some stereo equipment and get a surge? Good Luck!
