AC/compressor causes fluxes in voltage/rpm
Old 05-23-2008, 02:23 PM
GXPPOWER's Avatar
Default AC/compressor causes fluxes in voltage/rpm
when i turn on the AC and im sitting idle my voltage will flux alot. and sometimes get into the low hazard area. and rpms will drop sometimes alogn with it.
my ac makes a bad squealing sound when the compressor is on. grandfather thinks it is the clutch. im not sure. but can that cause my voltageand rpm to jump around?
Old 05-23-2008, 03:35 PM
9000th01ss's Avatar
It's the high speed fan causing your voltage issue. Not really a problem unless it dips down low and stays there.
The squeeling is probably the belt (which isn't the same belt that turns the alternator)
My belt squeaks, I sprayed some WD40 on it to be sure it was the belt. If the squeeling goes away it's the belt. I got a new belt and it didn't help. I greased the tensioner and idler pullies, didn't help.
I put on a goodyear gatorback belt and that got rid of the noise.
