rocker arm noise???
rocker arm noise???
my 2000 ls1 is making a weird noise i took it to aour local chevy dealership and they said they believe a rocker arm is loose. What it is doing it when im on the gas its fine but as the rpms are winding down its making a loud high pitched noise that goes with the same speed as the motor. My question is is this really the problem and if it is how hard and what do i need to do step by step to fix it or am i better off to just take it to them let them charge me $250 just to fix it any help is appreciated pictures anything... thanks guys Chris
You need basically three tools. A ratchet, an 8mm socket and a 10mm socket. And an optional inch pound torque wrench. Maybe a short extension.
Take the coil packs off (5? 10mm bolts), take the valve covers off (four 8mm bolts), take the rockers off (one 8mm each).
It's really that easy. no write up needed IMO.
EDIT: that doesn't sound like a rocker arm problem to me. The rockers do the same thing at any given rpm regardless of engine load or throttle position.
what do you think it may be then i dont want to do all this if thats not what everyone thinks the problem is i do have after market headers and have had those bolts back out on me before do you think that it could be that i didnt think it would be because its a higher pitched noise but at first i did think it was an exhaust leak.
How the hell does it sound like push rods?
The whole valve train does the same thing whether is revving up, coasting down, under load, or not.
It could be an exhaust leak, headers will pull a vacuum on the ports with the throttle closed, with MLS gaskets they can even make a whistle noise, or a high pitch squeel.
