water pump going bad?
Recently when i've been driving around, the water? temp gauge will go almost or into the red and the check gauges light will come on, After a few minutes it wil go off and the temp will go back to normal. The heat up usually happens during idle or low cruising speeds. I think its the water pump cause when i drive, especially when you press the gas a bit and in first or second gear at low accel there's a whining noise coming from the engine bay.
What do you guys think this is?
i'm not sure, it seems like they're working cause whe i turn the car off sometimes they'll remain on for awhile, and im pretty sure there was no manual fan switch installed so they should be coming on automatically i assume?
