a/c problems
Old 06-09-2008, 10:44 AM
99nbmws6's Avatar
Default a/c problems
i put some r-134a in my car the other day cause it was low, it blew cold air so i figured that it was all good, well i went to drive the car today turned on the ac and it blew warm air again. i got home checked it found it was low again so i put more in but it didnt seem that it want to fill in the ac. anyone know what the problem is?
Old 06-09-2008, 10:57 AM
DRGnFLYZ28's Avatar
Sounds like you might have a leak. If it's blowing warm don't keep running the A/C until fixed. Moisture will build in the system so you will need an evacuation and refill. First take it to someone to see if there is a leak and take it from there.
Old 06-09-2008, 08:23 PM
99nbmws6's Avatar
ok thanks i will do that
Old 06-10-2008, 02:44 PM
Daredevil_TA's Avatar
see if you can find someone with a leak detector or you can check the lines an see if you find any deposits of oil built up, thats usually a good indicator of a leak, should have a yellowish or greenish tint to it.
