Are the windows tied into the stereo????
Are the windows, and stereo wired together???
My stereo cuts on and off on it own, and when the stereo goes out the windows dont work...
any body else with this problem?????
it happens sporadically.....
The only way that the windows are related to the radio is the RAP (retained accessory power) system which is internally controlled by the BCM. Its either a faulty BCM or a wiring problem. Let your car run with the radio on and wiggle wiring harnesses that go to the BCM and where they go to the I/P fuse block and see if the radio cuts out when you are doing this.
