Coolant Flush question?
Old 06-25-2008, 04:26 PM
Greenbird97's Avatar
Default Coolant Flush question?
This will be my first time flushing the coolant system on the Trans Am. Just wanted to make sure i have all the steps correct. I tried to find a writeup but couldn't. What all do I need to do. My main question is do I drain the radiator, then fill with water, wait for the t-stat to open, then drain, and repeat or is there just a way to leave the car running with a hose in it and just leave the radiator plug open? Do i need to remove the block drain plugs? Do I need to open the purge valves? My other MAIN question, is how much actual coolant do I put back in when I'm done (1 jug, 6 quarts, etc)? Thanks for your help.
Old 06-25-2008, 10:18 PM
Anyone?
Old 06-26-2008, 12:12 AM
sleepinghawk's Avatar
Default how to
Try this
http://www.fbody.com/tech/details.cgi?id=50
Old 06-26-2008, 02:20 PM
Thanks for the link! If only there were pictures, lol.
Old 06-26-2008, 11:08 PM
Twisted636's Avatar
its easy todo don't forget the thermostat too. its always a good idead to change that when u flush.
Quick Reply: Coolant Flush question?
